Literally hundreds of pickup drivers report that going to bigger tires makes their MPG go down.
The rotational moment of inertia goes up with the square if outside diameter increase. that makes you accelerate four bigger "flywheels" as you leave every stop light.
If you want to slow the engine down - a valid fuel economy practice - slow down or regear.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
