not to mention HX prolly uses EGR and has a box mounted on the firewall by the vin, and 5wire wideband o2 sensor. that control box has a connector so you'd need a HX wire harness or manual to extend wires to the shock tower/ecu. also, as SVOboy pointed out to me - the fuel injectors are different they flow less fuel.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
