Old 06-09-2008, 12:48 AM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
The key is attached airflow along the length of the object, or the avoidance of turbulence.
You recall that the optimal aero shape- a falling drop- has a hemisphere for a leading edge, not a bullet. That is how it is for the very subsonic speeds we operate in.
So a blunt leading edge is OK so long as the flow doesn't go turbulent as it transitions to flow along the sides.
Right. Well I meant bullet shaped / egg shaped .... you know ... anything but a flat plate like they have on that Camaro.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
