Old 06-09-2008, 06:17 AM   #14 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by fshagan View Post
I'd love to do that. But I'm also attracted to Riley's idea of using a small diesel engine in front and an electric motor in back, and just using a manual switch over when you run out of electrons. Running the diesel on biodiesel would be ideal. The only problem is that he is looking at a Kubota tractor engine, which I'm sure doesn't pass California emission standards.
As far as top-coating polystyrene foam, epoxy resin does not melt it, but the polyester resin does (I'm not sure about vinylester). You could try epoxy resin over the blue foam; it may work well.
Fill your eyes.....with that double vision
