Old 09-27-2012, 06:41 PM   #20 (permalink)
some_other_dave
Speed is not a problem, use a bicycle speedometer. Fuel flow it the tricky one. Somewhere on the inter-tubes within the last maybe 30 days I was looking at a discussion of using the turbulence of two posts in the free flowing fuel shedding vortexes to sense small quantities of fluid flow.
Interesting!
Another way to do it would be to approximate it. You can get the tach signal (as I said, you'd have to filter it) and add a manifold pressure sensor, or possibly two sensors--one in the manifold, and one in the air cleaner. You should be able to approximate the fuel flow through the carburetor if you know the pressure differential across the metering nozzles in the carb. You might have to add a throttle position sensor to work out accelerator pump volume.
Heh, basically you'd be doing all of the calculations for fuel injection without actually powering the injectors.
Originally Posted by AndrzejM View Post
You can see one of the possible solutions of this issue here: http://ecomodder.com/forum/showthrea...tml#post292922
Thanks, I hadn't noticed that thread!
Originally Posted by botsapper View Post
Oh that tail. Someone has already photochopped it in...metal.
Looks a lot like a Tatra from some angles.
-soD
