Old 06-10-2008, 11:34 AM   #241 (permalink)
Yoshi
SuperMID designer
Yoshi's Avatar
You're welcome.
Originally Posted by dcb View Post
Any thoughts you'd be willing to share on the trip vs instant mpg discrepancy?
I've no time to figure it out yet, but I think you could.
I believe you can refer raw numbers for the variables and you'll find the cause is whether distance data or gallons, instead of the result of mpg value.
Or better yet, a generic way to multiply and divide 32 bit numbers while not overflowing but retaining max resolution (without a bunch of "if" statements)?
I know 32 bit data is better than 16 bit, but...
We observe approx 1% variance on the VSS and injector pulse width, therefore 1% accuracy is my target. I believe 0.1% internal calc error is acceptable, then 5 digit decimal value (or 16 bit data) is enough for our instrument.
Again, my suggestion is to place cli()/sei() codes for another interrupt driven variables, such as vssPulse and injector pulses.
Following is an example in instruction level. A 32 bit variable is sent to registers as follows and interrupts can be occurred any timing between instructions.
Code:
; a 32 bit variable is 0x0000FFFF
        LDS     R14,0x0244 ; R14<-0xFF byte 0 of 0x0000FFFF
        LDS     R15,0x0245 ; R15<-0xFF byte 1 of 0x0000FFFF
; an interrupt occurred, then it became 0x00010000
        LDS     R16,0x0246 ; R16<-0x01 byte 2 of 0x00010000
        LDS     R17,0x0247 ; R17<-0x00 byte 3 of 0x00010000
; then R17..R14=0x0001FFFF
Regards,
Yoshi
