FYI, we are working with a copy of a trip to avoid that exact interrupt interaction situation at display time, and the initial bench tests would indicate that the model is reasonaby correct at 32 bits after many hours of running. This mpg issue is a funky scaling thing I'm reasonably certain (and we would have the same problem no matter how many bits the numbers were).
