This has been productive
I think a good "base" to test any modification is with non-hypermilling driving habits 1st. (obviously) In the most controlled manor possible.
Do your 1st A-B-A test at posted speeds,
Then do the A-B-A test over with your own driving technique.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
