Old 10-17-2012, 03:15 PM   #11 (permalink)
Dztech28
Originally Posted by hamsterpower View Post
Keep in mind that bad input shaft bearings and worn 1-2-3 syncros(your grinding?) are EXTREMELY common in Civics. Don't rule out a repeat problem after two transmissions. I've had 4 different transmissions in my Civic and every one has had these problems to varying degrees.
its way too loud for a drive gear. it sounds more like the flywheel teeth are rubbing on something when the sound comes. It sounds like putting a card on the frame of your bike so that it can flick through the spokes of the wheel so you can sound like a harley. Im thinking the throwout bearing is not sitting on the clutch fingers or the flywheel is rubbing on the bell house. both sound the same for the two CX/VX trannies that ive had in.
