Old 10-19-2012, 09:19 AM   #54 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Have always figured that the accident risk is several times higher under adverse weather in that vein I set up my car for worst case. Dry handling is a no brainer, slip angles are only a fraction of bad weather.
I always try and pick tires that have a tread no wider than the wheel rim width. Going bigger means that I will have a tire tread that is bowed a lot more and is subject to uneven wear particularly at higher pressures.
Wide tires make for slippery handling in the wet and snow. Wide has to clear a lot more material in front of tire so that it can come in contact with the road.
Noah Webster, 1787
