12-29-2007, 12:41 PM
Giant Moving Eco-Wall
You can assemble this Hydrogen-On-Demand system from simple hardware in one weekend. We have specifically designed it with YOU in mind - for easy assembly at home using a few basic tools - and its major parts are:
1. Electrolyzer (some call it "Hydrogen Generator"): Our unique design has SPIRAL electrodes rather than plates, thus producing MORE HHO - for LESS energy from the battery. Contained in a quart-size highly durable jar. Looks fragile but it's not! We've never seen any of these jars break or crack, in thousands of miles of day-to-day road tests and I'm still using the same jar from 2006.
2. MAP Sensor Enhancer: this electronic device reduces fuel consumption without modifying the engine or the computer – an absolute must have for great fuel economy!
3. Vaporizer: ads water vapor to the engine to cool it down, improves combustion and fuel economy. Also serves as part of the "charged water system" that you will learn about. Good for almost any vehicle, generator or even a lawn mower!
4. Fuel Heater: pre-heats your gasoline for better gas economy, using only energy from the radiator that gets wasted otherwise. Absolutely NO modifications done to the radiator or its hoses!
5. PCV Enhancer: another great companion to your hydrogen system that improves the PCV (Positive Crankcase Ventilation) function, protects your engine and saves gas.
6. Fuse holder + wiring. Connect to the 12 volts.
7. Vacuum T-connector: helps you splice the vacuum line for feeding the hydrogen and oxygen into the engine.
8. Two vacuum hoses, 3.5 feet each. One connects to the intake manifold, the other to the air filter.
9. Mechanical installation hardware: Bungee cords, 8" cable straps (for Electrolyzer), 11" cable straps (for Fuel Heater), flex tubing (to protect the wiring harness), and 1/4" vinyl tubing.
10. Catalyst: household Baking Soda - totally safe catalyst! Catalyst is the substance that helps the electricity separate water into HHO. Distilled water alone does not conduct electricity so nothing would happen without this material. Can be obtained cheaply at your grocery store.
11. You will have everything you need to successfully install, operate and fine-tune your Water4Gas system for maximum fuel economy - "Just Add Water!"
Minimal System - The Secret Formula They Don't Want You to Know
IS THE ABOVE TOO MUCH TO BEGIN WITH? Do you want something EVEN SIMPLER to start with? No problem! Here is the ABSOLUTE MINIMUM you need to start SAVING FUEL in your car:
1. The Electrolyzer produces Brown's Gas: Hydrogen & Oxygen for your engine,
2. The MAP Sensor Enhancer tunes your computer to maximum fuel economy.
3. Several formulas given, mainly based on Xylene (Xylol) (some also with Acetone). Xylene can be obtained cheaply from hardware stores (paint department) and helps to atomize the fuel so it can be broken easily into smaller particles. This enhances combustion and saves much more money than it costs.
core system to save gas
You will find that these devices are very powerful, but also that each device is simple enough to build in a couple of hours from low-cost hardware. Once you have these "appetizers" in action, and you feel the power of this technology to save fuel in your car, I'm sure you will get the appetite to check out the rest of the technology revealed to you. It will actually be a good idea if you start with this minimum and then grow your Hydrogen-On-Demand system in several easy phases.
If you knew how it worked, you could just try it out on that old junker you were thinking about donating to the junkyard. I'm not trying it soon tho, seems too fishy to me.
