I agree that the gain would be nill. If everything's working as it should, leave it alone. If your carrier bearing or u-joints are shot then yes, switch over to a 1 piece. Fe aside, IMO it would be worth it just for simplicity. Also, what rear end gears do you have? My ranger (same as b-series) has 3.45's and was getting almost 30mpg when it was running right.
