Old 06-11-2008, 10:16 PM   #6 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I don't think the Venturi affect applies here -- that would be for when the air is in motion and the object is stationary. This is the object is in motion through the air -- and like an airfoil wing, with a flat bottom and a longer air path over the top, you get an increase in pressure under and a decrease in pressure above the vehicle = lift.
The slope up to the rear decreases pressure (because there is greater volume for the air to be in), and this would produce some small bit of downforce -- or at least less lift.
