Here is a picture from above (my porch) showing the taper in the sides. Also today I used my belt sander to smooth out and round off the edge where the top meets the side panels. You need to give the windshield adhesive two days to completely dry. I replaced the silver duct tape with some white tape so it would blend in with the panels better. The taper should allow me to put clear plastic covers over the tail lamps that blend in to the sides of the cap.
Tomorrow I replace the blower resistor (only works on high speed right now) and in the afternoon I will finish applying the window adhesive to the rest of the frame after I have removed some material from the wood blocks which is pushing the sides out where the taper brgins. Then I might let it sit for a day to make sure everything is completely dry.
regards
Mech
