Old 11-16-2012, 06:59 AM   #248 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Originally Posted by HydroJim View Post
That's what I figured. Not really sure why I asked, but it's good to get second opinions
Sounds like you have oil on the clutch.
Best bet? The faster you go the more likely the clutch will start to slip. The higher the gear you are in the more likely it will slip. Basically...the more load on the clutch the more likely it will slip.
So...if it starts to slip...reduce speed and drop to a lower gear. Depending on how bad it is...biggest problem will be going up hills in 5th? You might have to drop into 4th for these....
You can always drop down into 1st and 2nd (almost no load) ....you'll get there eventually.....
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
