Old 11-23-2012, 06:48 AM   #6 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by bertb View Post
Well, sorry to say I screwed that up.
What effect did it have ?
Let that decide wether you screwed up or not
But as ChazInMT says, we usually start with blocking the upper grille first.
Blocking the entire lower grille can also be a bit too much, depending on the weather and season.
And it can block air flow to transmission / AC / or inter cooler - if you have any of these, see that it can still get some cooling air.
Here I thought I was saving the planet and was going about it all backwards.
It's better to try and fail, than not to have tried at all
I smoothed out the front to make what I took to be the bottom part of an air dam.
It IS an air dam.
Just make sure you can get away (cooling wise) with this kind of blockage - and the top grille.
FYI : 1990s Honda's had little or no top grille .
