Old 11-24-2012, 01:01 AM   #102 (permalink)
Ecky
90 day: 40.51 mpg (US)
Originally Posted by brucepick View Post
My HX has the stock VSS and tranny and I see the same error on the OEM speedo and odo. I used the same solution: my MPGuino is carefully calibrated to my GPS and those Guino numbers drive my fuel log and mpg numbers.
Yeah, my MPGuino reads the correct speed as well, but the cluster isn't hard to fix. The spring getting weak makes it read incorrectly by a fixed amount, so moving the needle back corrects it perfectly.
turbovr41991 (11-24-2012)
