Old 11-27-2012, 07:33 AM   #46 (permalink)
Slow_s10
Super Lurker!
Slow_s10's Avatar
Rusty - '88 Chevrolet S10 base
90 day: 23.72 mpg (US)
Doc - '08 Honda Civic EX-L
90 day: 29.6 mpg (US)
I must have missed your picture before, but I was curious when you were saying that you used a peice of plexiglass over the whole front. Now I see what you mean. That probably helps as much as anything since the gaps alone on the front of these trucks are larger than the grill openings on a lot of newer cars. I thought about doing something similar when I had the Bravada grill on my truck as it sits flush with the headlights.But for now I am just going to probably remove the tow hooks and make some kind of block for those openings too.
I also see that you made a opening for your radiator. I think you mentioned that your engine was getting hot without it, and honestly that was one of my main concerns when I put the block on mine since it covers the entire grill. But so far the engine has not gone over around 200~205 even while sitting in stop and go traffic. I assume the fan is just able to move enough air through all the gaps in the bodywork to keep it cool. Gotta love GM.
-Kevin
