Old 11-27-2012, 09:16 AM   #25 (permalink)
Daox
Woo, glad to hear you got it to work out. Now you have a few options!
You don't need large sheets of fiberglass. You can just patchwork them together. A tip I got when doing this is to tear your fiberglass apart, do not cut it. It makes everything blend together better. You'll need to sand everything down eventually, at that point you can work out the higher points.
