Old 11-29-2012, 06:31 PM   #6 (permalink)
Electroddy
Electroddy's Avatar
I second what Oil Pan 4 said about the block. Remove the pan and look closely at the webs around the outer bolt holes. Also look closely around the cylinder bottoms. I have one of these blocks that has a small crack at the cylinder bottom due to core shift when the casting was made. This is/was a known problem with these motors. The best blocks are the ones from 82 83 as they have a high Nickle content.
ID:	11956   Click image for larger version
