I put in a set of 1" lowering springs from ST Suspensions for the Miata on the stock Aspire struts. The springs actually swap over perfectly. The new Aspire rear struts didn't come with new mounting bolts, so you'll most likely need to go to a junkyard to pick up some replacement hardware. The only hardware it comes with is a locknut for the strut rod.
NOTE: Springs must be for first generation Miata, '90-98.
In Reason we Trust
