Old 06-12-2008, 06:38 PM   #25 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I'm glad you like it It is just a mockup, it doesn't do anything and has not been integrated to the mpguino codebase, but here is the code if you are interested. I basically build the numbers with 5 custom block shaped characters (will need to get rid of the current custom characters for this)
PHP Code:
//GPL Software
byte brightness[]={0,42,85,128}; //middle button cycles through these brightness settings
#define brightnessLength (sizeof(brightness)/sizeof(byte)) //array size
byte brightnessIdx=2;
#define contrast 15
//LCD Pins
#define DIPin 4 // register select RS
#define DB4Pin 7
#define DB5Pin 8
#define DB6Pin 12
#define DB7Pin 13
#define ContrastPin 6
#define EnablePin 5
#define BrightnessPin 9
#define lcdpowerPin 15
//LCD prototype
class LCD{
public:
LCD( ) ;
void gotoXY(byte xbyte y);
void print(char string);
void init();
void tickleEnable();
void cmdWriteSet();
void LcdCommandWrite(byte value);
void LcdDataWrite(byte value);
byte pushNibble(byte value);
//main objects we will be working with:
LCD lcd;
void setup (void){
pinMode(lcdpowerPin,OUTPUT);
digitalWrite(lcdpowerPin,LOW);
pinMode(BrightnessPin,OUTPUT);
analogWrite(BrightnessPin,255-brightness[brightnessIdx]);
delay(500);
digitalWrite(lcdpowerPin,HIGH);
lcd.init();
pinMode(ContrastPin,OUTPUT);
analogWrite(ContrastPin,contrast);
lcd.LcdDataWrite(3);   lcd.LcdDataWrite(2);   lcd.LcdDataWrite(3); lcd.LcdDataWrite(32);
lcd.LcdDataWrite(0);   lcd.LcdDataWrite(0);   lcd.LcdDataWrite(3); lcd.LcdDataWrite(32);
lcd.print("INST");
lcd.gotoXY(0,1);
lcd.LcdDataWrite(1);   lcd.LcdDataWrite(1);   lcd.LcdDataWrite(3);  lcd.LcdDataWrite(32);
lcd.LcdDataWrite(3);   lcd.LcdDataWrite(1);   lcd.LcdDataWrite(3);  lcd.LcdDataWrite(4);
lcd.LcdDataWrite(32);   lcd.LcdDataWrite(32);   lcd.LcdDataWrite(3);  lcd.LcdDataWrite(32);
lcd.print("MPG");
void loop (void){
  while(
true){}
//LCD functions
LCD::LCD(){
//x=0..16, y= 0..1
void LCD::gotoXY(byte xbyte y){
byte dr=x+0x80;
  if (
y==1)
dr += 0x40;
  if (
y==2)
dr += 0x14;
  if (
y==3)
dr += 0x54;
lcd.LcdCommandWrite(dr);
void LCD::print(char string){
byte x 0;
char c string[x];
  while(
!= 0){
lcd.LcdDataWrite(c);
x++;
string[x];
//do the lcd initialization voodoo
void LCD::init(){
pinMode(EnablePin,OUTPUT);
pinMode(DIPin,OUTPUT);
pinMode(DB4Pin,OUTPUT);
pinMode(DB5Pin,OUTPUT);
pinMode(DB6Pin,OUTPUT);
pinMode(DB7Pin,OUTPUT);
delay(500);
LcdCommandWrite(B00000010);  // 4 bit operation
LcdCommandWrite(B00101000);// 4-bit interface, 2 display lines, 5x8 font
LcdCommandWrite(B00001100);  // display control:
LcdCommandWrite(B00000110);  // entry mode set: increment automatically, no display shift
LcdCommandWrite(B01000000);  // set cgram
  //create some custom characters
byte chars[]={
B11111,B00000,B11111,B11111,B00000,
B00000,B00000,B00000,B11111,B00000,
B00000,B00000,B00000,B11111,B01110,
B00000,B11111,B11111,B11111,B01110,
B00000,B11111,B11111,B11111,B01110};
    for(
byte x=0;x<5;x++)
      for(
byte y=0;y<8;y++)
LcdDataWrite(chars[y*5+x]); //write the character data to the character generator ram
LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
LcdCommandWrite(B10000000);  // set dram to zero
void  LCD::tickleEnable(){
// send a pulse to enable
digitalWrite(EnablePin,HIGH);
delayMicroseconds(1);  // pause 1 ms according to datasheet
digitalWrite(EnablePin,LOW);
void LCD::cmdWriteSet(){
digitalWrite(DIPin,0);
byte LCD::pushNibble(byte value){
digitalWrite(DB7Pinvalue 128);
value <<= 1;
digitalWrite(DB6Pinvalue 128);
value <<= 1;
digitalWrite(DB5Pinvalue 128);
value <<= 1;
digitalWrite(DB4Pinvalue 128);
value <<= 1;
  return
value;
void LCD::LcdCommandWrite(byte value){
value=pushNibble(value);
cmdWriteSet();
tickleEnable();
cmdWriteSet();
tickleEnable();
delay(5);
void LCD::LcdDataWrite(byte value){
digitalWrite(DIPinHIGH);
tickleEnable();
tickleEnable();
delay(5);
