Old 12-01-2012, 12:56 PM   #33 (permalink)
rattroddrebel
research hiatus
Thumbs up Huh?
Originally Posted by JRMichler View Post
Not so much skeptical as data driven. We really like test results when the tests are done as described here: http://ecomodder.com/forum/showthrea...ery-11445.html.
Usually the benefits of fuel additives disappear when tested correctly.
I dont agree. The problem is with all of the marketing tests the are tested in optimum conditions. I have done some testing, and I continue to do so in every tank. I have read that thread, the data is incomplete. Is this why I get so much friction on this forum? I even moved to the unicorn stable because if you mention fuel additives here you get stoned to death. But I will do some more reading, thanks for reading.
"Real Skill requires no effort"
crouching tiger hidden dragon
