Old 12-04-2012, 12:51 PM   #1 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Terminal F/E; What's yours?!
After playing around with my VAFC for a little bit (fine tuning Vtec engagement) I decided to find out what my terminal fuel economy would be using a very simple method... Given that my car runs at 2700 Rpms during cruising speed, I tested the unloaded engine (vehicle stopped, trans in neutral) for fuel consumption in gph and netted approx 45mpg terminal F/E
70mph / 1.55gph = 45mpg
This would be the resultant mpg my Acura would make at a constant 70mpg, flat road, with no rolling resistance, air resistance, or drivetrain losses. Obviously this on its own does relatively no good, but it does allow for a realization of expectations, and will help guide you with the use of EOC, DWL, P&G, DFCO, aero mods, etc. in order to help achieve your goals
So my question is, what's yours?
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
The Following User Says Thank You to nbleak21 For This Useful Post:
brucepick (12-04-2012)
