Old 12-04-2012, 07:47 PM   #11 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
There isn't a bolt-on solution to a better nose for that truck, however, you could probably make something work from a Camaro or Firebird front end if you know how to manipulate ABS plastic.
Flexible plastic epoxy is only like $6.99 a tube. You'd have to cut it in several places and make filler panels, but the width should be pretty close to fit.
