Old 12-08-2012, 10:00 AM   #4 (permalink)
2000neon
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Daox: The car already has an almost complete, invisible grill block as it sits right now (painted flat black and mounted behind the grill, + the factory VX grill block). I will be making something small first before I try the kammback itself though. I lobe your grill block on the Prius by the way.
WeatherSpotter: Thanks, that is good to know. The top area above the window and in front of the kammback that hinges with the hatch will be easiest to make from wood, so I'm glad to hear that should work.
