Manual conversion sounds interesting, but no room for the shifter. Roof rack holds the hand truck in an overflow situation. This van has 135 cubic foot of usable cargo capacity and every bit of it is used - I mean ALL of it, all that's left is the driver seat and most days there is no more than a small hole to see out the passenger window and mirror.
The 98 received a 2.3 vtec engine that had roller rocker arms and 3 valve mode that operated identical to the vx - a bit more efficient. Interesting that they perfected the driveline and chassis for one year then produced a piece of crap destined for trans failure.
Tire pressure is maxed, grill block is soon to come, not sure about the air dam because of the height and steep leading edge angle of the vehicle's nose, diverting a considerable portion of the air under might be better after a bellypan is installed.
