Old 12-09-2012, 04:17 PM   #64 (permalink)
Texasc1985
Rat Truck - '12 Nissan Frontier SV
90 day: 20.99 mpg (US)
Aero Shell
Your camper looks great. What kind of sheathing did you use?
Another easy way to squeeze more mpg is to advance the timing. On engines with an actually distributor I would advance them until it dieseled after the ignition shut off and move it back 2-5 degrees.
If the truck has an OBD-II (post 1997 vehicles) Bully Dog Tuner set at 87 octane and reset the timing 2 degrees or so.
2012 Nissan Frontier 4.0 V6 - pre mod 19.6 mpg, last tank 23.25 mpg and current tank with timing adjustment is at 30 mpg on scanner.
