Old 12-09-2012, 05:10 PM   #65 (permalink)
radioranger
radioranger
pretty amazing MPG , I sprayed some choke cleaner through the intake and it seemed to help quite a bit after it burned off the o 2 sensor, pretty smooth , Getting 27.5 mpg now with the grille block and loosened up brakes , pumped up the tires to 35 and floats right along now, so on the right track, am adding the two stroke oil next fill up and will note change again if any, ran it on straight fuel for a while , also redline sythetic N/s wiihout the limited slip additive for the diff. , supposed to be so slippery that limited slips wont work so sounds promising ,used it once long time ago and loved it , noticed a change right off idle, , pricey though at 16 a quart , also in the works are a rear bed cover out of plywood, last two feet and foot and a half or so beyond bolted on top of bed, would like though an adjustable wing so I could air brake it also, very light in rear on highway now, braking is a big issue with studded tires, ,
