Old 12-10-2012, 03:07 AM   #19 (permalink)
darcane
darcane's Avatar
Originally Posted by a8ksh4 View Post
darcane & Duffman, you haven't had any trouble passing smog after running the 2-stroke mix?
No, but I don't think I have quite as strict of standards to worry about. Our emissions check for OBDII cars is just checking the gas cap and connecting to the OBDII port. If the ECM doesn't report any codes, you should be a pass here.
If you are concerned, stop using it a tank or two before the smog check.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
