Old 12-11-2012, 11:22 PM   #484 (permalink)
user removed
You also have to believe that the electrical energy from your alternator can be increased without an energy cost, which seems to be where the ignorance of the HHO advocates becomes glaringly obvious. Adding a load to the charging system is the same as climbing a grade with the vehicle. You can try but there is no way you can get free energy. The energy you get cost you at least 3 times more than the usable energy you recover from your HHO system.
The most efficient energy storage device of which I am aware is a hydraulic accumulator, which under ideal circumstances can approach 99%.
regards
Mech
