Old 12-12-2012, 01:24 PM   #68 (permalink)
user removed
236.4 miles on $7.09 gallons @ $2.919 per gallon, 33.34 MPG. Best tank so far even with the colder temps. Picking up the 15 inch wheels Sunday morning. I probably won't get them on the truck for a while and just wear out the tires that came on the truck, date coded 2009. Not bad considering the last tank on the Fiesta was just over 41 MPG. Checked the tires pressure after about a month and every tire is holding pressure without any significant drop in pressure.
No engine off coasting, not sure if I want to subject things to that kind of treatment. For all I know right now the clutch and timing belt may be originals. I'm going to check the timing belt soon, when it gets a little warmer.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
aerohead (12-12-2012), slowmover (12-12-2012)
