Old 12-12-2012, 08:23 PM   #70 (permalink)
user removed
The bright metal Pizza Pans at Wally World are 16 inch which should work perfectly with the 15 inch wheels. I'll use some wierd star pattern socket for the fastener so no one will have one of them to steal the covers. I think the Pans are $3.98 each. Hoping the center caps are metal (1990 most probably) and are held on by the lug nuts so I can just use them for mounting the Pans. Probably not even make holes for the valve stems, just carry the tool (probably special made by me) for removing the pans, in the glove box.Use a single bolt in the center with some rubber around the edges, with a large washer to spread out the clamping force.
regards
Mech
WesternStarSCR (12-12-2012)
