Old 12-14-2012, 02:22 PM   #11 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by sarguy01 View Post
I need to do some research for the best weight oil this thing can use for it's high mileage/MPG and what fluid to put in the trans.
I've already done the trans oil research for you:
Use GM's Synchromesh semi-synth gear oil. DON'T use the 75w90 oil called for in the owner's manual - I believe that's a printing mistake, and here's why:
Effect of gear oil viscosity on transmission efficiency (Metroid owners take note) - Gas Savers - Fuel Efficiency Forum
sarguy01 (02-13-2013)
