Old 06-13-2008, 10:53 PM   #44 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile Will the uneven loading cause a belt failure
1/ Checking the new head over, i found that the intake valves will miss the cam with the buckets out but the exhaust will not. I can over come this by putting in a couple old exhaust valves and grind off the valve tips enough to clear the cam.
2/ Also the timing belt would be seeing unusually spaced pulses with the buckets out scenario. it would be very jerky.
Will the uneven loading cause a belt failure?
