Old 12-23-2012, 04:51 PM   #1 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Vx or d15z1 lean burn drivers do you eoc?
I know the advantages of eoc. In my old d15b7 I was getting 43 with normal driving. When I started eoc I achieved a best tank of 50.7 mpg. I'm nervous to try it with my new sensor in the vlx. I have heard that after a long eoc the sensor needs to heat back up for lean burn to work. Is that true? Can this damage the sensor in the long run if using eoc on a daily basis? The longest eoc I would do is 5 miles at the most. I don't want to take life away from the sensor that is so expensive.
