Old 12-24-2012, 10:37 PM   #1 (permalink)
DIMS
Bad Flat but made it home :)
I think this is the worst flat I have ever had!
It bike is related right and there are pics
I rode to work & started to notice a bad shimmy coming from the rear tire, but it was dark & I was almost to work. I left work & forgot to check the tire & the shimmy got really bad on the way home. When I got home I noticed the tire a bit low, so tried to pump up the tire, but it would leak air anything above 60PSI.
Hmmm weird? I inspected the tire and this is what I found...but first let me tell you how I protect fromm flats. I use a tube protector strip 2X thick version, 5x thick inner-tube With Slime to boot & supposedly a protector tire with 5,000 plus miles. Maybe the tires were just a bit worn out!
