Old 12-24-2012, 11:57 PM   #88 (permalink)
RatherDashing
I finally got the whole issue fixed iv been lookn at the whole time.just the tps needed realigned.fixed the throttle issue right away.the throttle stop screw is stripped.and the map sensor screws r stripped.
I thought i had to realign the tps closed throttle voltage via the throttle stop screw.i just turned it til it hit .45 then tightnd it down.totally fixed it.
I might need one later.but im running on quite a tight budget and fixing one thing at a time every two weeks.
Now just need plugs wires.axle shaft seal.throwout bearing. and radiator which is on order.
Yur right up is epic btw.especially the pcv valve.is bad pcv valve noticed in lean burn with hesitation? Im hopn that replacing the wires with ngk wires and ngk plugs fixes that issue
