Old 06-14-2008, 05:51 AM   #33 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
The need for distilled water is simply to keep the unit clean. As the water is broken down any impurities will remain. Eventually the generator needs to be refilled as it'll run out of water. The impurities continue to build up and will eventually short the generator.
The thing MUST have the salt in there in order to work! Salt IS an impurity, too. And yes, any and all impurities will built up as a crust on the electrodes.
So again, why would one use distilled water -- and then add an impurity? (Which will build up inside the plates.) The only reason I can think of is to try and control the rate of conductance -- though he sure doesn't measure it, like he said in the instructions...
