Old 12-26-2012, 09:27 AM   #5 (permalink)
SmellyCat
Thx everyone for your input
KennyBobby, Running rich seems logical. My Mpg got up to 27 mpg in the summer and the last few tanks are 21-23, with alot of coasting in N. I figured it was cold weather. The CEL is not on. I wonder what I can do on the cheap to lean out this engine. I will do the WOT test and report the egr vac psi.
BTW. the timing belt skipped 2 months ago and I reset it. The engine seems smooth so I figure its set right. If I'm off a tooth would that make it rich? Would'nt run rough if the belt was off?
