Old 12-27-2012, 01:38 AM   #10 (permalink)
turbovr41991
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
I had this transmission in my 1986 mr2. Took a little modification to make it work in the mid engine setup, but worth it. Like it alot. It is a little different than the C60 and is intended for the A block (aka 4AGE).
Originally Posted by serialk11r View Post
If it's really a C160, it's probably worth more like 2000 dollars if it's in acceptable shape.
I sold mine for $500. Most seem to get 500-700 latley
Not a non-A engine Toyota.
It IS an A engine. The Blacktop 20 valve is part of the A block series. I had this trans mated with a stock MR2 engine and the 99 blocktop 20 valve 4age. Both worked flawlessly. It is also a drop in swap for a corrola.
