Old 12-27-2012, 12:44 PM   #8 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Set the heater as low as possible without freezing the pipes.
A Minimum-Maximum thermometer to see how low / high temps get would likely help.
Do something about the draft - that's what's costing you most as it takes the heat out and brings the cold in.
As you have a constant loss, "pulsing and gliding" the heating will help.
Constant heating will simply mean a constant, higher loss.
The smaller the difference between temperatures inside and out, the lesser the heat loss will be.
I'd either insulate the place better, or look for a better place to start with.
You could talk to the owner about insulation, as it also improves his property value.
These pipes are uncovered, but again, are "insulated" by the bathroom.
A bathroom isn't a very good insulator
Covering the pipes and heating through a radiator is more efficient than taking away heat from pipes that run through a room..
Can I pulse and glide the heaters?
At work, we've just installed P&G electric heating in a natural gas line (expanding gas cooled down, froze the tiny amount of water in it, and locked up control valves)
