Old 12-28-2012, 06:34 AM   #2 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
If you can put a ScanGauge (or maybe an UltraGauge??) in it you should be able to read engine temp digitally.
My Civic also doesn't cool the coolant much when at idle speed. I think that's pretty standard with an engine-driven pump.
Sorry I can't try interpret the temp sensor data. Radiator's return hose should feel cooler than the upper hose, definitely.
The fans definitely put a load on the alternator and thus on the engine. I avoid any setup that causes my (single) fan to run a lot. That definitely affects your fuel economy.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
j12piprius (05-01-2014)
