Old 12-28-2012, 08:27 AM   #3 (permalink)
user removed
Have the radiator checked for partial blockages. I would think a 2004 model would still be good but radiators will transfer less heat when they get older, just like cholestrol in humans restricts blood flow. Also make sure the cooling system is "bled" properly if you have done anything that could cause an air pocket, which can also cause the problem you describe.
regards
Mech
ron (12-28-2012)
