Remember what aerodynamic drag really is... its the amount of force on the vehicle from you accelerating the air in the direction of the vehicle. Drag is dependent on two things: 1. how much air & 2. how fast you accelerate that air forward (in the direction of the vehicle).
Want to REDUCE drag? Reduce the amount of air impacted (smaller frontal profile) or lessen the acceleration of the air (smooth the flow over the length of the vehicle).
**Don't forget you are pushing the air in the front (high hanging fruit), and sucking the air in the back (lower hanging fruit)**
HOW THIS APPLIES:
The lessen the amount of air that you have being pulled forward by the protrusions under the car by reducing the gap between the car and the ground. This will reduce the amount of air available to be accelerated. It will probably have the same acceleration, but less air means less drag.
Other aerodynamicists chime in...
Ryan
Reason: Poor flow (pun intended) ... tried to rewrite for ease of reading.
