Old 12-28-2012, 11:02 PM   #2 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
I forgot to mention that another benefit to doing the delete this way is that a breather can be easily added where the two hoses connect if desired. I have only driven about 40 miles since the mod but it appears to have given a decent increase in MPG. I notice that the steering is easier with the system looped and some of the fluid removed from the rack than it was just EOC'ing with everything in place. I will try to quantify the belly pan and power steering delete once I run through a couple tanks.
The Following User Says Thank You to 1carnut For This Useful Post:
j12piprius (04-22-2014)
