Old 12-29-2012, 06:41 AM   #4 (permalink)
radioranger
radioranger
well on boats they water cool the exhaust and use a water to water exchanger instead of water to air like a car does., suppose all the present radiator flow went into a barrel and returned, then if you got too much heat an extra coolant loop with a small radiator could be switched on , or just use a water cooled exhaust only then if temps go too high vent the steam
