Old 12-31-2012, 01:30 PM   #62 (permalink)
Demolite
Demolite's Avatar
Carina - '93 Toyota Carina E GLi
After a long time I'd like to share some things i noticed with my system. I recommend you don't use straight coolant to coolant transfer, the expansion system is very hard to do and the pressure of the cooling system doesn't stay in normal limits. Core plugs started to leak and the Uno's head gasget blew, propably as a result of coolant leakage. I suggest using insulated tubing to transfer heat and a pump in the system makes controlling and transferring heat quicker.
The Following User Says Thank You to Demolite For This Useful Post:
California98Civic (01-26-2013)
