Old 01-01-2013, 08:51 AM   #3 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
The fan on my Focus starts at 233F and shuts off at 222F. In summer FWT will regularly run over 200F...maybe from ~204F up to 210F? FWT is one of the readings I use all the time.
I'll probably go ahead and cover 2/3s of the rad...I do have the LED indicator mounted right on top of the SG. It's when I see running temps above 200F that I see the good mpg.
I might come up with a grill cover that is easily mountable and that has a sliding panel in it for adjustment....something with clips on it to be easily removed.
It's the "scary high" that you need to worry about...theory being that this weakens the headgasket over time due to too much movement....
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
