Old 01-02-2013, 12:33 PM   #33 (permalink)
pete c
been giving the small garage idea more thought. Trouble is it's kinda big and expensive. How about something smaller that would be more like a boot that could just cover the front clip? Make it about four feet tall, maybe 2 ft wider than the car, stuff it with lots of fiberglass batt insulation with a tarp on the inside which would hold the insulation up. Opening with the car not there would be a little smaller than the front clip. As you pull into it, the tarp/insulation expands for a nice cozy airtight fit. You could even place insulation on the floor which would sit roughlt the same height as the bottom of the car.
Done right, there would be virtually no airflow. I would think that such a device could keep the engine at least warm to the touch overnight.
I think you could build this for under 100 dollars.
The Following User Says Thank You to pete c For This Useful Post:
WesternStarSCR (01-03-2013)
